JFG
Apr 20 2018, 02:51 PM
I started to refurb mine tonight. The picture below shows the only 2 fittings that i have with them.
As i lost the tear down pictures i don't have a source of info to refit them and what is used.
Does any of the usual suppliers make a fitting kit for these? How do they attach in between the screws shown?
Finally are these covers meant to have a slight turn/twist in them towards the rear?
sholman5
Apr 20 2018, 04:07 PM
The rubber acts as a spacer between the cover at both ends and fender and quarter panel lower lip. Remove the rubber spacer from the screw. Place spacer between the cover and fender and quarter panel lower lip. Insert screw in hole located in lip.
sholman5
Apr 20 2018, 04:17 PM
sholman5
Apr 20 2018, 04:31 PM
Rivots were factory.Aluminum. Most people just use stainless screws.
jcd914
Apr 20 2018, 05:31 PM
It seems to me 914rubber had a kit with the rubber spacers.
Jim
Apr 20 2018, 05:51 PM
Fuel hose will do in a pinch. Also, plastic or aluminum rivets are easier to drill out to inspect the rockers. I’m told that’s why the factory used plastic. Cut them off with a knife. 914rubber has them.
rgalla9146
Apr 20 2018, 07:35 PM
The hardware shown is correct for the ends. Not shown is a clip that attaches to each end of the rocker cover that the screw threads into.
There is no curve toward the rear.
porschetub
Apr 20 2018, 08:26 PM
I put spacers under the lower mounting bolts, hard to get in but leaves a gap for the road grime to fall out,use luded stainless bolts to stop stripping out the body inserts.
JFG
Apr 20 2018, 11:32 PM
Thanks for the info. I'll get on to mark for fittings. If i'm not mistaken the plastic/aluminium rivets may be the same as the ones for the covers on the step just above these covers.
saigon71
Apr 22 2018, 05:28 AM
I used small stainless steel screws to attach my rocker panel covers in the door jamb. Makes it easy to remove and inspect periodically. Just throwing it out there as another option.
Big Len
Apr 22 2018, 05:35 AM
QUOTE(saigon71 @ Apr 22 2018, 07:28 AM)
