I have a Rennshifter installed with center console and carpet , etc, I want to change the Shifter Throw from the lower hole to the top hole to reduce the amount of shifter travel. In directions it say to remove the shifter (PITA) Can this be done with the shifter installed in the car? Also Is anyone running with 4/5 left gate spring removed? Seems Heavy (without shims) Maybe I am just used to the old with no spring on that side??? If I pull the spring, do I pull the button out too?
-Robert
Reverse, 1st, 2nd, and 3rd... Are just AWESOME
-Robert
