Jopojone65
Apr 25 2018, 01:49 AM
Hello, where to connect the conductor number 30 in d-jetronic. Some help advises you to the ground, but is the instruction correct?
JeffBowlsby
Apr 25 2018, 08:05 AM
Circuit #30 is the TPS ground, which is also in the ground connections with the injector grounds at the top rear of the engine case.
