what is the difference from the 914 to 911 front suspension?
why swap?
QUOTE (messix @ Jun 7 2005, 11:11 PM) |
so the spindles are not the same? you cant swap the hubs and rotors? |
QUOTE (Aaron Cox @ Jun 7 2005, 11:13 PM) | ||
negative. big negative. 914 rotors have the bearings built in 911's have hubs...bearings in the hubs....and the rotor bolts to the hub |
QUOTE |
slightly beefier torsion bars |
QUOTE (JOHNMAN @ Jun 8 2005, 01:35 PM) | ||
I think only the splines on the ends of the torsion bars are different. I think that you can get the same "stiffness" torsion bars with either 914 A-Arms or 911 A-Arms. (of course, when one goes to coilovers, it is a moot point) |
QUOTE |
so, i stand by my statement, 911 bars are slightly beefier (and noticable too) |
QUOTE (Aaron Cox @ Jun 8 2005, 04:51 PM) |
STOCK 911 Bars - 18.9mm STOCK 914 Bars - 17mm so, i stand by my statement, 911 bars are slightly beefier (and noticable too) |
QUOTE |
my understanding of t/bars is that dia. of the splines will be consistant on the bar and the shaft dia will very with the rating of the bar, stiffer thicker/ softer thinner. |
