AnthonyM
Apr 26 2018, 08:29 PM
What size bolt is used for the 6 pressure plate bolts for a 914-4. All stock parts.
Mark Henry
Apr 26 2018, 09:31 PM
I'd have to measure one but it's an M8-1.25 grade 8.8
bdstone914
Apr 27 2018, 08:51 AM
90007510401 B8 x 15, Hex Head bolt, grade 8.8 minimum.
A longer bolt 20mm bolt will work as it is a through hole in the flywheel.
AnthonyM
Apr 27 2018, 01:24 PM
Any washers? Flat, spring or lock. The bolts are 20mm in length.
porschetub
Apr 27 2018, 04:31 PM
I used 20mm 8mm HT capscrews and spring washers, already had the capscrews new so used them up,I tend not to reuse the old ones.
