I'm looking to replace my rear window is this a simple in/out replacement or a major operation usually done at restoration time ?
TIA Dennis
djway
Apr 27 2018, 01:55 AM
You just need to remove the surrounding interior parts, pull glass, clean, lay down butyl and reinstall in reverse order.
falcor75
Apr 27 2018, 02:47 AM
And remember to save the bottom edge rubber spacers when you pull the old glass.
Wyvern
Apr 27 2018, 03:13 AM
Good time to replace the window to rear deck "seal" as well if needed. And a good time to wind up your seat belt spring a bit as well if it needs a bit of help.
I am doing Sail Vinyl and rear window reset as we speak. Find instructions for Sail Vinyl replacement as that is the process to get to the window. (With a few less trim pieces to remove)
It's pretty straightforward. I managed to do it correctly in one attempt a few years ago. Everything else I do seems to require three tries before I get it right...
EdwardBlume
Apr 27 2018, 07:07 AM
I used 3M window adhesive in a coil pack. Just be aware that you have one shot to get it on right because that stuff sticks.
Mikey914
Apr 27 2018, 08:30 AM
We sell the complete reinstall kit for $20 including new spacers.
