QUOTE(crsedge @ Apr 28 2018, 09:25 PM)
QUOTE(914Sixer @ Apr 28 2018, 11:03 PM)
Craig,
I have a nos VDO fuel gauge that is needed for building the gauge. The stock console gauges are 60mm. Take the guts out and drill the 2nd light hole in. I have some used studs for bulbs from old gauges. Use the offf set rubber from the fuel light. Use the 60 mm dial face from the volt or temp gauge. Drill hole in face for low fuel light. Have face rescreened to match GT dial face. The only difference is there is no mounting studs on the back of case.
Pretty sure NHS can do all this for you if you have a used console gauge and this nos gauge.
Thanks 914Sixer.
I might pass on this one and aim to get one the correct 60mm size to start with.
Cheers
Craig
Here's a SAAB gauge and the first GT style gauge made for me by NHS in '05:
Click to view attachmentSubsequently, I sent it back to them to change the graphics and add the longer needle. I sent them the last SAAB gauge I had and they returned two, long needle fuel gauges to me:
Click to view attachmentThis is one currently installed in my center console:
Click to view attachmentAs of this date I have one long needle gauge remaining.
