QUOTE(Jeff Bowlsby @ May 1 2018, 09:38 AM)
So, this is a bit of a conundrum. I have personally seen and built dozens of 74 and 75 1.8L harnesses. All the 74s have had 2 wires at the TPS, and the 75's 3 wires. I have never seen a 74 harness with 6-pole AFM and a 3 wire TPS.
Total respect for Clay in his observations of 3 wire TPS's for 1974, I don't doubt your observations, but my experience has been different. OP above documents the 74 TPS on his car - 2 wires.
I checked the FWSM - yep, it shows 3 wires for both 74 & 75.
I checked other Bosch manuals including theory books - yep 3 wires for the TPS in all cases.
I checked the 912E information I have - 2 wires as Clay mentioned. The #2 wire controls idle, which my information says is controlled by pins 36 and 39 on the AFM. The 912E information confirms this and only has 2 wires for WOT control on the TPS because idle control is through the AFM.
So there is a conflict between the physical harnesses I have seen, the FWSM, Clays and my observations of physical harnesses.
Not sure how to interpret all this.
I am not saying you are wrong, but my observation over 33 years has been all three wires on a L-Jet TPS.
Jeff... you and I are going to have to research it. I have a bunch of factory harnesses stored as spares. Let me look at them and see if they have two or three wire TPS connections.
