ablesnead
Apr 30 2018, 11:14 AM
Here goes a short novel on what I am selling....I know that photos are essential , but they are delayed a little...I am a computer neanderthal ...., and This car will likely need be bumped a bunch , to find that particular buyer, so I have decided to start now. I am selling my long term track car project ( was building for the Targa De Newfoundland )...I am old and don't have time to finish.....A 1974 914 that started as a complete finished rotary engined conversion car...It ran and drove fine . here's what the 25000.00 I have spent so far has resulted in : Rust free car....you wont find anything other than surface rust, on some interior spaces , car from New Mexico and Nevada . A complete 220 hp streetport 13b rotary built by Adkins in California..51mm modified weber.in perfect running condition with very low hours , a rebuilt 901 that shifts as it should , engine and box combined weigh less than a stock four...the finished car will be 220 very reliable horsepower and weigh less than 1800 lbs.. what is accomplished so far...rear Tangerine style rear flairs welded on but not yet blended in...top with a fiberglass air scoop bonded on...7000.00 dollars worth of front suspension...elephant racing , monoball rsr , cutom travel struts , tarret bar / aluminum cross piece ,massive front rotors with aluminum hats , rebuilt and new powder coated big red cailpers ( now big neon greens )...the rear trailing arme reinforced with chromemoly tubes , elephant racing bushing....tangerine racing outboard trailing arm mounts , raised strut top mounts , and reinforced inboard trailing arm mount...rear trunk is cut out back to trans mount area, traing arms are mounted with new bearing , new vented rotors and neon green powder coated boxster calipers,,all brake lines are run using pmb stainless steel lines , fuel lines are Tangerine racing stainlees steel ones , return for fuel injection included in install , shifter is rennshift with wevo hollow knob ( 100.00 dollar shift knob ...300.00 dollar accelerator pedal with 27 parts )...what an idictation !..Bruce stone redone pedal cluster...1000.00 dollars worth of revolution gauges cutom made 916 style front an rear bumpers...made to allow more air to radiator, so bigger opening and the rearumper vented at with flatter profile that doesn't stick out as far...car has good wheels and tires 17 inch 911 wheels and good tire it has a 914 rubber flat tow bar , and pullds straight ant great...I am going to sell this whole thing for 10000.00..I know I will have to be patient...I will not part out, many other new or refurbished parts go with it ...two real carbon fiber race seats , 1000.00 dollar fluidyne heat exchanger , mounts ect .....
matthepcat
May 1 2018, 05:24 PM
You are missing:
Your Location
Your asking Price
Pictures will be key.
May 1 2018, 05:35 PM
"I am going to sell this whole thing for 10000.00"
It sounds like a lot of nice parts but impossible to tell from the description the current condition of the car.
Mueller
May 1 2018, 06:55 PM
QUOTE(matthepcat @ May 1 2018, 04:24 PM)
You are missing:
Your Location
Your asking Price
I offered to help post them if he emails them to me. He said once he gets some he'll pass them on.
Blue6
May 2 2018, 08:56 PM
Bump
Jetsetsurfshop
May 3 2018, 02:29 PM
Heard a lot about this car. Can't believe your selling it.
2mAn
May 4 2018, 09:55 AM
QUOTE(ablesnead @ Apr 30 2018, 10:14 AM)
A 1974 914 that started as a complete finished rotary engine conversion car...It ran and drove fine . Here's what the $25,000 I have spent so far has resulted in:
- Rust free car....you wont find anything other than surface rust, on some interior spaces , car from New Mexico and Nevada .
- A complete 220 hp streetport 13b rotary built by Adkins in California
- 51mm modified weber in perfect running condition with very low hours
- A rebuilt 901 that shifts as it should
Engine and box combined weigh less than a stock four...the finished car will be 220 very reliable horsepower and weigh less than 1800 lbs..
- Rear Tangerine style rear flairs welded on but not yet blended in
- Top with a fiberglass air scoop bonded on
- $7000 dollars worth of front suspension. Elephant racing , monoball rsr , custom travel struts , tarret bar / aluminum cross piece ,massive front rotors with aluminum hats , rebuilt and new powder coated big red (now big neon green) calipers
- Rear trailing arms reinforced with chromoly tubes , elephant racing bushing
- Tangerine racing outboard trailing arm mounts , raised strut top mounts , and reinforced inboard trailing arm mount.
- Rear trunk is cut out back to trans mount area, trailing arms are mounted with new bearing
- New vented rotors and neon green powder coated boxster calipers,,all brake lines are run using PMB stainless steel lines
- Fuel lines are Tangerine racing stainless steel ones , return for fuel injection included in install
- Shifter is rennshift with wevo hollow knob ( $100 shift knob... $300 accelerator pedal with 27 parts )
- Bruce stone redone pedal cluster.
- $1000 dollars worth of revolution gauges
- Custom made 916 style front an rear bumpers...made to allow more air to radiator, so bigger opening and the rear bumper vented at with flatter profile that doesn't stick out as far.
- Car has good wheels and tires 17 inch 911 wheels and good tire
- 914 rubber flat tow bar , and pulls straight and great.
I am going to sell this whole thing for $10,000. I know I will have to be patient...I will not part out, many other new or refurbished parts go with it ...two real carbon fiber race seats , $1000 dollar fluidyne heat exchanger , mounts ect .....
Heres the OG post, with a little less neanderthal script. Much easier to read and you can now see the value of the car.
Any pics yet?
ValcoOscar
May 4 2018, 10:21 AM
burton73
May 4 2018, 01:15 PM
QUOTE(mepstein @ May 1 2018, 04:35 PM)
Ye
s pictures please.
I do not realy know what you have here.
Bob B
Fatboy007
May 6 2018, 10:19 PM
pictures
ablesnead
May 8 2018, 07:49 PM
ablesnead
May 8 2018, 07:51 PM
I'm trying to learn to post photos...
ablesnead
May 8 2018, 07:53 PM
maybe this will work..
ablesnead
May 8 2018, 07:54 PM
another
ablesnead
May 8 2018, 07:56 PM
another
ablesnead
May 8 2018, 07:57 PM
another
ablesnead
May 8 2018, 07:58 PM
another
ablesnead
May 8 2018, 08:01 PM
another
ablesnead
May 8 2018, 08:02 PM
another
ablesnead
May 8 2018, 08:03 PM
another
ablesnead
May 8 2018, 08:06 PM
my rendition of singer style mirrors..factory made vent windows fit perfect...
ablesnead
May 8 2018, 08:08 PM
another
ablesnead
May 8 2018, 08:11 PM
more
ablesnead
May 8 2018, 08:12 PM
more
ablesnead
May 8 2018, 08:14 PM
again
ablesnead
May 19 2018, 12:51 PM
another photo and a bump....new carbon fiber seats ...very light
rabrooks
May 19 2018, 08:23 PM
I'm interested. I'll pm you
jd74914
May 21 2018, 03:23 PM
Where is the car located?
Lots of nice parts there...
2mAn
May 21 2018, 04:19 PM
Now that theres pics, this should sell quick!... Im tempted too, but its a bit more on the project side than I want
Jetsetsurfshop
May 25 2018, 11:27 AM
Did it sell?
burton73
May 25 2018, 11:47 AM
QUOTE(Jetsetsurfshop @ May 25 2018, 10:27 AM)
Did it sell?
Where is it at?
Bob B
Jetsetsurfshop
May 27 2018, 06:33 AM
QUOTE(burton73 @ May 25 2018, 09:47 AM)
Did it sell?
Where is it at?
Bob B
Florida
ablesnead
May 28 2018, 05:40 PM
not yet....
ablesnead
Jun 3 2018, 02:13 PM
bump...also 8000.00 with a stock motor , or without motor....
burton73
Jun 3 2018, 09:19 PM
QUOTE(ablesnead @ Jun 3 2018, 01:13 PM)
What do you use for emergency/Parking brake for rear?
Still hard to understand this. Was the car running when you started this before you put all the parts on. And there are things missing like Torsion shafts up front. Steering Bellows. Do you have all these parts?
Why is the rear trunk cut out a little? If you make this easier to understand you may get a sale from someone here. Water cooling set up?
So I guess $10,000 all in $8,000 with a stock 914 Eng? What would that be or $8,000 no eng.?
Bob B
ablesnead
Jun 8 2018, 02:47 PM
coil overs in front...was complete running street car when i started...car is now a track car project..trunk cut out is to facilitate track side access....water cooled car ..water lines run inside longs..will sell for 8000.00 with stock 13b rotary , that should be rebuilt as desired
burton73
Jun 8 2018, 07:40 PM
What is up with the 220HP Eng. that you comment on. Do you have all the pieces for the car? Hood , Trunk, Eng. Lights. What king of shape ae they in.
Bob B
ablesnead
Jun 9 2018, 09:25 PM
sorry your question ..what is up with 220 hp engine ? is unclear to me ..
infraredcalvin
Jun 16 2018, 10:30 AM
QUOTE(burton73 @ Jun 8 2018, 06:40 PM)
Bob B
If you’re interested in the motor, I may be interested in the rest of the car... maybe we can work a deal?
Pat
burton73
Jun 16 2018, 10:54 AM
QUOTE(infraredcalvin @ Jun 16 2018, 09:30 AM)
Bob B
Pat
Looking at it as a water-cooled project. If I did it I would want the full car.
Questions on what is used for a parking break. I am too fat for this car. Lots of holes for weight savings. Good or bad?
Bob B
ablesnead
Jun 16 2018, 08:00 PM
QUOTE(infraredcalvin @ Jun 16 2018, 12:30 PM)
Bob B
Pat
I will keep the motor , if you just want the rest of the car for 8000.00
Jetsetsurfshop
Jun 17 2018, 02:15 PM
Hey Lorin,
PM me your address. I want to try to come over and check it out.
Shane
ablesnead
Jun 21 2018, 09:53 PM
I have tilton bias adjuster nib for the car and also hydralic clutch kit nib .bump
a9146luvr
Jun 21 2018, 11:17 PM
Where is the car/parts located, and I assume the "220 hp" powerplant is a Mazda 13b rotary engine? I assume also all the parts that made it a working/driving 914 prior to teardown are included (ie, radiator, oil cooler, eng mount etc), right?
ablesnead
Jun 24 2018, 02:18 PM
Stuart Florida , and yes ...
Fatboy007
Jun 24 2018, 09:29 PM
QUOTE(Blue6 @ May 2 2018, 09:56 PM)
Bump
ablesnead
Jul 2 2018, 01:52 PM
bump
ablesnead
Jul 8 2018, 11:59 AM
bump
ablesnead
Jul 16 2018, 08:14 PM
bump
ablesnead
Jul 26 2018, 04:09 PM
bump
