nsr-jamie
Apr 30 2018, 11:20 AM
Hi, been busy and not posting here for a while. Getting my car up and running again and the rear trunk does not close. Hinges are fine. The latch is worn out, the long pin or lock (don't know the name) is seriously worn out and it does not fit into the female part anymore....looks like I need a new one. Are new ones available? I will try o attach a picture to explain better. If anyone has any advice let me know please. Thank you
TheCabinetmaker
Apr 30 2018, 11:28 AM
Take it apart and you will see it's conical shaped with a notch. The end of the cone and notch wear down and won't latch. Build it up with welds then grind it back to shape. Weld and grind till it latches.
nsr-jamie
Apr 30 2018, 11:31 AM
I was thinking about that too, are not new ones available or even just the actual pin ?
brant
Apr 30 2018, 11:46 AM
I have the same problem
and it just started failing 3 weeks ago as I was preparing for rt66
I was thinking about asking bruce or some of the common sources for used parts to sell me one.
I wish a brand new pin was available (rather than buying a used one)
I will follow this thread!
brant
dr914@autoatlanta.com
plenty of new available also just the perch
nsr-jamie
May 1 2018, 09:51 AM
QUOTE(dr914@autoatlanta.com @ May 1 2018, 02:46 AM)
Hi , the first place I looked was your site but could not find it on your site and posted here. I was thinking about a used one but since they wear down a new one would be best...
I just need the pin, the long part that fits into the hole. I don't need the spring or other parts....can you let me know prices and also I am in Japan so need shipping...its a small part so shouldn't cost much I guess...I also need a speedometer cable as well...my car is a 1972 4 cyl model on steroids. Thank you
Bartlett 914
May 1 2018, 10:40 AM
I am sure Garold has several
914work
May 1 2018, 10:52 AM
Do you just need the pin?
Elliot Cannon
May 1 2018, 11:07 AM
Have you tried adjusting the length of the pin?
McMark
May 1 2018, 03:51 PM
I've never seen one that couldn't be adjusted to work. Take a picture with the spring compressed. Cause I wanna see what this 'serious' wear looks like and learn what to watch out for. (no sarcasm)
McMark
May 1 2018, 03:52 PM
Oh, and try putting that part into the bottom-latch and see if it stays.
914Sixer
May 1 2018, 05:05 PM
New complete assembly from Sunset Porsche $119
dakotaewing
May 1 2018, 05:46 PM
Doesn't bdstone914 also have these replated and ready to go?
Mikey914
May 1 2018, 06:39 PM
Guys Id be happy to make just the pins, should be relatively inexpensive.
Mark
nsr-jamie
May 2 2018, 12:47 PM
QUOTE(McMark @ May 2 2018, 06:52 AM)
tried that already, does not fit anymore...tried everything, the pin is worn down there are no sharp edges on it like that picture 914 werke posted,
if someone has a new pin I would be very interested, thank you
nsr-jamie
May 2 2018, 12:49 PM
QUOTE(dakotaewing @ May 2 2018, 08:46 AM)
is that Bruce? is he still in the 914 parts business? I should contact him....tried in the past but did not hear back from him
bdstone914
May 2 2018, 04:25 PM
QUOTE(dakotaewing @ May 1 2018, 04:46 PM)
I do not have any pins. The bottom of the pin gets beat up and damaged. I do not have any more good ones.
Yes I say have Mark at 914 Rubber make the part. I could use at least six or more to assemble complete ones.
and for McMark I will post pics of the bad ones I have.
Bruce
May 2 2018, 04:32 PM
91451204111
maybe you could file the pin and make it work again, since the rest of your latch is good. We have many many used pins, and since you are such a great customer of ours, we can send you a used one for free with your next order Jamie
QUOTE(nsr-jamie @ May 1 2018, 08:51 AM)
nsr-jamie
May 4 2018, 02:03 AM
Hi George, thank you!! So how can I go about this...I would also like to order a speedometer cable while I am at it. My car is a 1972 1.7L model with a sideshifter transaxle. Thank you. Jamie
QUOTE(dr914@autoatlanta.com @ May 3 2018, 07:32 AM)
91451204111
nsr-jamie
Sep 4 2018, 06:10 AM
Hello George, I would like to order...how can I go about getting started please, thank you
91451204111
adolimpio
Sep 4 2018, 07:41 PM
