PDXMike
May 3 2018, 03:09 PM
I am installing a windshield washer fluid pump. I have a rear window defroster that doesn't work, and that I have no plans to use/fix. I want to use that switch to power the pump. Do I need to use a relay, or can the switch handle that kind of load for short bursts?
brant
May 3 2018, 03:24 PM
you can modify or replace the actual wiper stock on the column to incorporate a switch onto the control stock
Dave_Darling
May 3 2018, 04:45 PM
Not on an early car, you can't...
The defroster switch is made to run a relay feeding a pretty good-sized current draw. Even though the motor might not be as large a load (and definitely not as continuous as a defroster) I would still play it safe by using a relay.
--DD
