Sunday I installed my new Hyfire CDI box. I've had it for a while and finally found the time to do the entire installation in one fell swoop. I couldn't test it at the time because some other parts were still off the engine, but I was pretty careful, and confident it would work just fine. The only questionable item in my mind was the fact that I'm using a Crane Cams (PS-92) CDI coil, but I think that should be ok.
Last night I got the rest of the engine ready to fire up and turned on the ignition. First I set up the rev limiter , then the number of cylinders, and I thought it was time for a cranking test. I turned the key and didn't get any sparky sounds so I looked at the light on the CD box that the instructions say will blink while cranking. Steady light, no blink. Hmm, that's a bad sign.
I went to the engine compartment next to check my connections. Everything was hooked up but ... what's that?...
WTF. The red wire goes to the green wire and the green wire goes to the red wire. I don't think that's right. I certainly don't remember hooking it up that way Sunday. Making that connection was the last thing I did before cleaning up.
Which one of you snuck into my garage and reversed the connections?
So I switched the wires back and,hoping against hope cranked the engine over again. NO change. Last chance. Perform the test procedure on the Unilite Module. I get about 12 volts at the coil negative position whether the optical trigger is open or closed. Its fried.
What a dumbass I am sometimes.
I did the same thing to a Pertronix a long time ago... and again to my Crane Hi-6 about 8 years ago.
Do you ever wonder what makes us turn off our brains and act like absolute morons once in a while? Maybe it never happens to you, but I've certainly had my share of braindead experiences, without even being drunk or on drugs, to use as an excuse.
I got a new module today, so I'll try again later tonight. :fingerscrossed:
