This is a nice party trick. My girlfriend was very impressed. Almost impressed enough to make up for the fact that it didn’t start in the first place...
A note to thieves: you still need the key in the cylinder otherwise the wheel will lock like normal.
You’re going to need two wires. Tie one end of each wire together. I had some small male connectors I keep in the car with my wiring kit which are helpful to keep everything from falling apart.
Click to view attachmentStep 1 is to remove this plug from the back of the cylinder. You have to stick your head up under the dash to see it. A flat head screwdriver is helpful for this if you can fit your fingers up in there.
Click to view attachment Step 1.5 make sure you’re in neutral with the handbrake on! Ask me how I know.
Step 2 plug your double end of the wire into the terminal corresponding to red wire #1 (terminal #30) on the diagram. This plug is always “hot” with (relayed?) power coming from the battery, so be careful to not let the other ends of the wire short out on any grounds in the area.
Step 3 plug one of the other ends of your wire into the terminal corresponding to black/red wire #62/63 (terminal #15). This sends power to your ignition system. You should hear the turn signal relay clicking when you plug this in. If not, put the car in neutral and put the handbrake on you dummy!!!
Step 4 touch (do not plug in) the other wire end to the terminal corresponding to yellow wire #65 (terminal #50). This cranks the starter. Just touch the wires together. Don’t plug it in all the way unless you normally drive around while holding the key in the cranking position.
Step 5 plug the free end of the wire you were just using in step 4 into the terminal corresponding to red wire #10A (terminal #X). This gives power to all your lights and turn signals.
That’s it. Pretty simple even a hack like me can figure it out. To turn the car off, just yank out all the wires. I don’t think you can just carry a spare switch and plug it in unless you also carry a second key to keep in the original switch to prevent the wheel from locking.
Thanks Jeff for the diagram and the help. I owe you a beer.
