We replicated both of the cooling flaps that are often missing or get damaged easily. Most do not have the foam seals on them any longer as the disintegrate over time.
We also did new drive pins for attachment as I've been told from a reputable source that they too are also missing if the flaps are. The factory designed these this way for a reason. looks like a little detail, but why did they do it? It probably made a difference to them if they paid to do it. We now have the correct configuration for these.
You can find them here -
https://shop.914rubber.com/Pressed-Air-Inta...m?categoryId=-1
sign up here to get the complete set both flaps with foam attached and the pins for $22. will be $35 after the GB.
I also put the cooling flap bushings on sale (look in the related items above the listing on the site). If you are replacing the flaps you probably want the bushings too.
So who wants em?
