bob's project
May 4 2018, 05:54 PM
Hello,
I would like to purchase 2 or more L-jectronic injectors for my 1.8L
I am only interested in Bosch / OEM ones
Please let me know if you have any available.
Thanks in advance.
Bob
ClayPerrine
May 5 2018, 06:31 AM
I don't think that there are any factory injectors left. But I can make a suggestion. Find 4 injectors from a 1982 Nissan/Datsun 280ZX. They are identical to 912E injectors, and work perfectly in a 914 with L-Jet.
bdstone914
May 5 2018, 07:35 AM
I have a few used untested L jet injectors. $10 each. I can test them for actuation. If you go the used route get at least four, have all of ours sent out to cleaned and tested for flow and pattern. Take the four closest matching ones based on flow. Or if you can find new 280ZX injectors replace yours with a set of four.
Are you in Australia? Your access to injector servicing companies may be more limited than what we have in the states. If you are interested I could send out what I have for testing and cleaning.
bob's project
May 5 2018, 11:37 AM
Thanks for the reply and suggestion Clay. The 280 injectors seem to be just as uncommon in my area. The only new ones seem to be from standard motor products which I'd rather not use.
bob's project
May 24 2018, 03:38 PM
Still in need. Please let me know if you have any available.
Thanks,
Bob
mtndawg
May 24 2018, 05:00 PM
You might be able to have them reconditioned by these guys, or maybe they have a set?
http://fuelinjectioncorp.com/
914Sixer
May 25 2018, 07:35 AM
There is a couple over on theSamba.com $75 each NOS Bosch. Pull up fuel injectors under search.
