porscheaddic
May 4 2018, 09:29 PM
Selling this 1970-1971 Porsche 914 steering column with ignition switch. They key turns a d functions properly. Missing turn signal arm. Asking $200 plus shipping.
Thanks
JeffBowlsby
May 5 2018, 08:04 AM
I could be interested if its 12 pin connector was not cut off. Or is this the later 1971 version with a 14 pin connector?
porscheaddic
May 5 2018, 02:23 PM
Jeff,
Not sure if this is a 1970 or 1971? Are the two years interchangeable?
Thanks
JeffBowlsby
May 6 2018, 09:14 AM
70-early 71 are 12 pin. Late 71 is 14 pin. The two are not interchangeable. Without the connector the internal wiring is useless, all that is left is the case. Too bad the connector was cut off, it simply could have been disconnected.
