I have a persistent problem with an engine miss that I can't figure out. I have a 73' 2.0 with F.I. and electronic ignition. The car starts and runs great but about 10 minutes after driving, it begins to miss enough that the car jerks while cruising. It idles fine and doesn't seem to be miss until I start out again. If I shut it off for a few minutes and restart, it runs great for a few minutes but when it gets warmed up again, the miss returns.
I recently changed the coil, rotor and cap and have checked the timing which is good. I removed the spark plugs to check them and #2 & 3 are good and #1 & 4 are black. I changed out the carboned up plugs with good used ones and the same plugs quickly turn black. Is this caused by the FI trigger points? Are #1 & 4 run off the same set of points or do I have a different issue? I have some basic tools like a timing light, dwell meter and multimeter.
Any ideas on how to track down the cause of this miss? It began last fall and seemed to be fixed with the coil change but now that I have it out of storage and am driving, it's back.
Thanks in advance.
Warrenoliver
