Hey George,
It looks like there was something wrong with 2 of your pages which don't display:
attachmentid=650202
attachmentid=650206
You can recheck your list of attachments to see what's up with them.
Also, that D of the scanned 914 Factory Manual for Section 8 has several pages which were misfed scans & aren't readable to various degrees. It would be most helpful to those of us with your 914 CD if you could rescan them & post here, so that we can print substitute pages.
The misfed "914 Manual - Section 8 Body" pages/diagrams follow the pages which you scanned & posed above, & are denoted by the bottom page or illustration key as:
20.1 - 1/3 "Front Body Assembly" (at angle & partially off page, parts on 4 sheets with none complete)
20.1 - ?/? "Rear Body Assembly" (probably is 20.1 - 2/1)
(no page/illustration number is readable, all is vertical streaks for picture & text on 2 sheets with both streaked & unreadable)
20.1 - 8/1 "Replacing Section of Front Body Assembly"
(Cut off or split on 2 pages - would be better reduced or scanned as one oversize page for readability)
The above aren't actual page numbers, but the subsections for the 8 Body group, so their titles in quotes above from the tops of the pages & looking at the CD or print-out should help you ID them.
If you look at the CD version, these same bad pages are there, so it wasn't a problem with the print shop who printed out my hard copies in binders.
TIA!
Tom
