I have a /6 2.7l with dual Weber ida3c’s. The engine was running great then last week I did two changes on my car. One was that I repositioned my air fuel gauges. I have dual AEM widebands- one for the drivers side bank and one for passenger side. In addition, I had to do some minor wiring work on my alternator which required me to remove my carbs, linkage, shroud, and fan. I did not remove the fuel hoses, I just unbolted the carbs and moved the out of the way. There were no major changes. I put new carb manifold gaskets on when reinstalling. No carb adjustments were made.
Now when driving, the 4,5,6 bank now reading a air fuel ratio of >21 and the other bank reads normal. The car is now sluggish from idle and idles rough. Occasionally when Erving the engine, the a/f ration shots down to 10 for a second. Seems to be running hot and doesn’t start as quickly as normal.
Things that I considered that might have caused the problem.
-plugged idle jets- checked and cleaned- no change
-since I just moved the gauges- some sort of gauge issue. I doubled checked all wiring and all seems fine. Also- why would the engine be sluggish and hard to start if it was just a gauge issue? Doesn’t seem to be the case.
-I check the linkage and there were no changes and everything seems to be functioning the smoothly. No adjustments were made. Could a linkage issue cause a lean issue like this?
-maybe I bumped the distributor when removing the shroud? Why would only one bank be an issue then?
-fuel pressure issue? I have a gauge before the fuel line splits to each carb and it’s running at 3 psi.
-intake leak? I replaced and double checked each intake gasket.
Ideas?
