MikeM
May 13 2018, 10:55 AM
Hi all...
I recently changed the intake manifolds on my carbed 2.3 liter and realized the stud on the right side front is stripped. Is there a repair possibility that doesn't require an engine drop? Any thoughts??
Thanks.
TheCabinetmaker
May 13 2018, 11:11 AM
easy enough to drill, retap, and use a step stud or time cert, or helicoil where it sits.
iankarr
May 13 2018, 02:12 PM
Is it stripped in the head, or are the threads stripped outside? If in the head, I just did this with a helicoil. Not a big deal at all. Just make sure you use some hi-temp loctite to secure it.
Outside the head, you can probably just vice grip the stud, back it out and replace.
MikeM
May 13 2018, 03:08 PM
Did you have trouble getting the heli coil in with the engine installed?
I'm sure the threads in the head are stripped.
TheCabinetmaker
May 13 2018, 04:06 PM
Two responses have told you yes. How much verification do you need?
