simonjb
May 13 2018, 04:24 PM
Need some help/advice
I managed to lose one of the small bolts that has a hole through it so that the heater cable wires can connect to the lever
Do I try to make one - or are these available ? I can't seem to find the part number.
mgphoto
May 13 2018, 09:32 PM
They are called barrel nuts, it's the same nut on the accelerator cable, at the throttle body.
They are still available.
Sorry my mistake, I though you were referring to the heat exchanger end.
The ventilation switch is a single part, according to the parts book. You may have to find a used one.
simonjb
May 14 2018, 07:32 AM
Thanks
I managed to find the part number 901.211.683.00
simonjb
May 14 2018, 07:17 PM
I found it on eBay and then googled it
