EdwardBlume
Jul 11 2003, 08:36 PM
I just noticed while I was changing tires that my drivers side rear inner swing arm has about 1/4 inch play where the 3 17MM bolts are. The bolts don't seem to tighten either.
What's the cause / problem? Fix?
THANKS
ChrisReale
Jul 11 2003, 09:13 PM
Are they stripped?
EdwardBlume
Jul 11 2003, 11:24 PM
I didn't pull the bolts but they seem to be on very tight. This is where the "shim" is for the camber adjustment.
Is it common for these bolts to strip???
ChrisReale
Jul 12 2003, 12:17 AM
Are they torqued to 50 lbs? Each? Other than that, I have no idea. Do not over tighten them, I can only guess how fun it would be getting those bolts out after they break
Dave Cawdrey
Jul 12 2003, 12:36 AM
Maybe the plate circled below is F'ed up (bent, missing, etc.)
Just an idear...
EdwardBlume
Jul 12 2003, 06:43 AM
THANKS
The plate is there, it just shifts. I think its off because of the camber angle. Time for new bolts? Thanks for the torque setting, I'll give it a go.
THANKS AGAIN
