Freezin 914
May 17 2018, 07:49 PM
I have had a set of 16x7 VTO wheels with a 35mm offset, I am thinking they wouldn’t work on my narrow body car? Is this correct? I believe I would need a 23.3 offset? I will try to look through older threads..
Mueller
May 17 2018, 08:04 PM
Those will fit better on the rear than a 23mm offset since they will be inboard 10mm more, still might have tire clearance issue if running 205/50's on a bone stock rear fender.
I test fit my 23mm 7" wide rims on my car and the rim pokes out past the fender a good 1/2".
TravisNeff
May 17 2018, 08:11 PM
Good looking wheels, they will be close. What size tires are you going to run?
JmuRiz
Might work, it’s between the 911R’s 49mm offset and the normal 15/16x7’s 23.3mm
All depends on your car’s fenders though. All cars are a bit different.
914Sixer
May 17 2018, 08:25 PM
Factory Fuchs are ET40. Tire size will determine what will work and what won't.
Freezin 914
QUOTE(Travis Neff @ May 17 2018, 09:11 PM)
195/55, maybe 205/50, not entirely sure.
914Sixer
Factory 4 bolt Fuchs are ET40. Tire size will determine what will work and what won't.
Freezin 914
May 17 2018, 08:32 PM
The car currently has empi style 5.5’s and is very close to rubbing outer quarters. The grand plan is to change out the 100# springs and put in a set of ground control adjustable coil overs with bilsteins and 140# springs, have the set pictured, another very similar set in charcoal, but even considered a set of cookie cutters I have, of maybe sell the whole works, and go aftermarket RSR Fuchs....I need some help here.....4 lug? 5 lug? I like everything, maybe I need a few more cars!!!! Opinions welcome...
JamesM
May 19 2018, 02:15 PM
This is the exact wheel I run and have convinced a couple other locals to run as well, ET35 is perfect for the narrow body cars to run the widest possible tire. I havent seen 205/50/16 be an issue and you may even be able to go 215 depending on your car and what tire you run. At ET40 the inside of the 215s rub the front strut. ET23 on a 7 inch wheel will rub the fenders on a narrow body. Having a 7" wide wheel with shorter tire sidewall is a huge handling upgrade over stock.
Click to view attachmentClick to view attachment Click to view attachment Click to view attachment Click to view attachment
Freezin 914
May 22 2018, 06:05 AM
QUOTE(JamesM @ May 19 2018, 03:15 PM)
Excellent pictures, your car looks great! Thank you for the information!
JamesM
May 23 2018, 12:56 AM
QUOTE(Freezin 914 @ May 22 2018, 04:05 AM)
Thanks! The good looking one is my buddies but ill take the complement!
porschetub
May 23 2018, 11:27 PM
QUOTE(Freezin 914 @ May 18 2018, 01:49 PM)
Not a bad looking wheel never heard of them?,good luck with fitment.
sportlicherFahrer
Mar 17 2019, 12:37 PM
Recently stumbled across these. Curious how well they fit with a 205/55. Performance tire selection in 195/60R15 is non existent these days.
sixnotfour
Mar 17 2019, 12:44 PM
