firstknight13
Jun 9 2005, 08:33 PM
ok i had my door panels redone they came out awesome!!! here is the problem now that the padding is much thicker my window cranks wont go on with out RUBBING the panel. is there some deeper cranks available 1/4 inch +++ so i dont ruin the new panel??? thanks in advance.
tat2dphreak
Jun 9 2005, 08:35 PM
bug cranks fit the same, but you may have to put a spacer there to fix your problem..
xsboost90
yeah mine rub alittle on the door panel too! I would take a small washer and get a slightly longer screw...wala!
firstknight13
Jun 9 2005, 08:38 PM
the only problem with that is the teeth don't catch then?????
Cap'n Krusty
Jun 9 2005, 08:40 PM
You have the plastic washer in there? About the same daimeter as the hub of the crank. The Cap'n
firstknight13
Jun 9 2005, 08:46 PM
with the washer in the handel still rubs the panel. cant i get an extension?? or do i have to fabricate one??
xsboost90
Jun 9 2005, 08:58 PM
should be able to do one washer w/o loosing the contact w/ the teeth.
