HansJan
May 22 2018, 09:48 AM
Hello,
I’m looking for a spare wheel. Needs to fit the 5 lug (at 130 mm BDC) pattern.
Thanks for looking.
theer
May 22 2018, 10:14 AM
Hans,
need more information - 15", 16"? Any particular design: Fuchs, BBS, doesn't matter?
By the way, modern Porches mostly all have the 5 x 130 bolt pattern, so a cheap spare might be a phone dial or cookie cutter wheel from the 944 crowd. Just be sure the offset works with your set up.
914Sixer
May 22 2018, 11:17 AM
Boxster wheels will work too
jim_hoyland
May 22 2018, 11:22 AM
Like this steel 5 lug ?
HansJan
May 22 2018, 12:10 PM
The car has 16 Fuchs on it.
It has standard breaks and the disks are redrilled (from 4 to 5 studs).
Looking for spare that fits into the standard spare tire space, in the front.
Don’t care about the design or looks.
It’s not being used for windshield washer.
Hope that is enough info.
burton73
May 22 2018, 12:23 PM
If you put a tire that is fat the carpeted hard board that sits above it will not sit right.
Try to get something that does not weight that much.
Bob B
burton73
May 22 2018, 12:24 PM
Jims spare should work well for you.
914Sixer
May 22 2018, 12:34 PM
You can pick up 6x16 Boxtster wheels for $100. 911 16" spare wheels are $300 and up.
Gulf91474
May 22 2018, 01:17 PM
Got this sitting around.... 60$ Plus shipping.....
HansJan
May 23 2018, 09:40 AM
QUOTE(Gulf91474 @ May 22 2018, 02:17 PM)
What size is it?
carl k
May 23 2018, 08:16 PM
I have this one in San Jose, CA. Code 613 3E translates to 5 ½ x 15 (later 911) ET=42
Click to view attachmentClick to view attachmentClick to view attachmentCarl K.
