Dr Evil
Jun 9 2005, 11:14 PM
Does anyone have a pic of how the dizzy is installed on a /6? I need to know where #1 should be and the rest of the plugs.
Thanks
sixnotfour
Jun 9 2005, 11:21 PM
There is a little notch on the dist. where # 1 should be , pointing out towards the fan radially , or close to it.
Dr Evil
Jun 9 2005, 11:43 PM
Then do I just place the plug wires in this order; 1,6,2,4,3,5 around it clock ways?
sixnotfour
Jun 9 2005, 11:45 PM
Yep, unless its a SC motor. You Can put #1 anywhere you want unless you forget.
Dr Evil
Jun 9 2005, 11:46 PM
Why is it different for an SC motor? I have SC cams in my 2.7, but cant see why that would be an issue.
sixnotfour
Jun 9 2005, 11:48 PM
I said Motor, SC cams no prob.. SC Distributor rotates counterclockwise
Dr Evil
Jun 9 2005, 11:49 PM
Ah, I see. Thanks, Jeff.
Series9
Jun 9 2005, 11:54 PM
Hehehe
Dr Evil
Jun 9 2005, 11:57 PM
ya, ya I know, you had money.
sixnotfour
Double double , Double Vision.
I got one of those for my 3.0 twin plug
Series9
Jun 9 2005, 11:58 PM
QUOTE (Dr Evil @ Jun 9 2005, 10:57 PM) |
ya, ya I know, you had money. |
HAD being the key word....
Mueller
Jun 9 2005, 11:59 PM
QUOTE (Dr Evil @ Jun 9 2005, 10:14 PM) |
Thanks |
i thought you are running the crankfire ignition???
sixnotfour
Jun 10 2005, 12:01 AM
Crank sig, sparkin thru dizzy ?
Dr Evil
I will do the MJLJ as soon as I can get it running and broke in. I don't want to test out a crank fire system on a fresh rebuild
