StarBear
May 25 2018, 07:43 AM
The rubber button and ring combination is really annoying - the button/horn keeps getting knocked out of alignment with road bumps and stuff, leaving the horn loose and not/barely working. Keep having to redo (or replace) button and wire. Any clever alternate fixes to this? Thanks!!!
bdstone914
May 25 2018, 08:30 AM
QUOTE(StarBear @ May 25 2018, 06:43 AM)
Buy a new one.
https://www.pelicanparts.com/catalog/SuperC..._pg3.htm#item14
StarBear
May 27 2018, 08:21 AM
Yeah, been doing that - replacing it every 3-4 years. Fortunately not a big ticket item, but thought a) everyone has these 914 typical problems and b) someone smart has figured out a more thoughtful workaround. Still trying to find that little female spade connector - mine broke off a dozen years ago and eyes just can't "thread" the wire into that little hole any more. :+(
914Sixer
May 27 2018, 10:00 AM
Same old story, the new ones are not the same as the originals. Rubber compound is not the same.
Larmo63
May 27 2018, 11:00 AM
I run a hockey puck horn button, but I've never had any issues with the rubber cuff.
They do have to be very carefully installed, but no issues.
McMark
May 27 2018, 02:09 PM
The latches for your horn button may be bent, or the securing screws may be loose.
StarBear
May 30 2018, 01:35 PM
Thanks all for your input. Worked with my long-time buddy Jerry Rigg to fashion a female spade connector (broke 20+ years ago) for the wire onto the male spade (can't see that tiny hole anymore) and added three #6 SS washers underneath the horn ring plate in the batwing to "move" the plate a bit closer to the base plate on the steering wheel. Also tightened screws (they WERE loose) and replaced the button with a new one, so now very tight and firm.
dr914@autoatlanta.com
May 30 2018, 02:23 PM
the 73-76 horn base plate was always a problem as if the screws loosened and the horn boot was dried out, the wire would break off the tiny male spade made into the horn button. We finally made a new horn base plate to solve this broken spade problem, and Jorge at sierra madre makes an insulator kit that we too sell.
QUOTE(StarBear @ May 30 2018, 12:35 PM)
porschetub
May 30 2018, 04:32 PM
The engagement lugs can get bent and the batwing/hockey puck won't compress the rubber cuff fully.
The aftermarket ones seems to be a softer rubber than the genuine part or atleast that's what I found.
