I got a 1972 914 1.7L about 3 months ago, and have been working on getting it on the road since then. So far I've replaced the fuel lines throughout, and the front flex brake lines (the passenger side was leaking). After replacing the flex lines I've bled the whole system twice (so I got out all the cruddy looking brake fluid).
My problem is that every once in a while, maybe once in 3-4 drives, I would press the brake pedal and it would be much softer than usual. It already is not very hard to begin with, but this is soft enough to get my heart racing (haven't tested to see if it goes to the floor, but it might). After pumping it 1-2 times, the brakes feel normal again, and stay this way for the next few days. (So it's not happening every time.) When I showed it to my mechanic he stepped on the brake pedal and stayed with his foot on it for a while, to see if it slowly loses pressure. He said it feels normal. But he also said that if it has gone soft on me a few times he would probably try to replace the master cylinder preventively.
Is a faulty M/C the most likely culprit? Or should I try to bleed the brakes again? I have no leaks any more now, and the brake fluid level stays perfectly constant in the reservoir.
As an aside, the caliper on the driver side front must not be retracting fully, because that wheel always feels a bit hotter than the other one after driving. Could it be that I am boiling some brake fluid and that causes the pedal to go soft? (I would think that if that happened the pedal would stay soft for a long time, wouldn't it? So it would not go back to normal with 1-2 pumps.)
