QUOTE (type47 @ Jun 10 2005, 10:36 AM) |
probably what the cap'n means, but i just took 2 pieces of flat metal stock roughly 4-6" long and strong enough, and put in the 8mm bolts until they touched the stock, now located under the hub, and gently tightened, that is, screwed in the bolts to try to force the hub off the crank. cheap enough and i am.... |
