Good California donor car parts:
1. Both inner and outer rear driver side suspension consoles. $180 shipped in US. I will further cut them out from the frame with a cutoff wheel unless you prefer local pickup. You get to drill out the spot welds, or weld in the complete section.Click to view attachmentClick to view attachment
2. Front windscreen cowl corners. some rot, but each allows you to pre-build your own repair part without starting from scratch. Good for fixing rotted front trunk gasket channel. $25 for the pair plus shippingClick to view attachmentClick to view attachmentClick to view attachment
3. Tail panel - local pickup Los Angeles/Orange County area only. Makes fixing a dent or rusted out panel easy. has some of trunk floor and heat shield. $100
