andreic
Jun 10 2018, 04:29 PM
The other week I had some problems with low fuel pressure on my 1972 914 1.7L. I have now diagnosed these by pulling the tank out -- one of the hoses under it was kinked.
However, while inspecting the fuel tank I discovered that there is no "sock" inside the tank. How worried should I be? Should I use this opportunity that the tank is out to add a sock? Or is it not a big deal to run the car only with a fuel filter, without the sock?
Thanks,
Andrei.
bandjoey
Jun 10 2018, 05:01 PM
Important
TheCabinetmaker
Jun 10 2018, 05:55 PM
I thought Jeff did a good job of answering that question in your other thread!
andreic
Jun 10 2018, 06:04 PM
Got it. I already fully emptied the tank, I'll get a new sock and install it. As far as I could understand, this involves taking out the larger fitting from the tank and installing the sock over the end of it the tube that goes into the tank. Do I need any kind of washers/gaskets to seal the fitting back to the tank when I put it back in?
Thanks,
Andrei.
jim_hoyland
Jun 10 2018, 06:42 PM
Years ago, a Porsche mechanic suggested deleting the sock and let the easily replaceable filter catch any debris. Kinda made sense since the filter gets replaced periodically anyway; the sock is another story.
Thought this made sense Considering the fuel socks proximity
worn
Jun 10 2018, 08:43 PM
QUOTE(andreic @ Jun 10 2018, 02:29 PM)
Thanks,
Andrei.
I don’t see how you can replace the sock with fuel in the tank, so now is the time. They are cheap and easy to find. On the other hand fuel injectors are expensive and carb rebuilds take time and care. Have to say this is a clear choice. At least for me.
914 RZ-1
Jun 10 2018, 09:58 PM
Does someone have a picture of this sock? My '72 does not have one.
Any links to Pelican Parts or other vendors that carry this would be appreciated as well.
Lucky9146
Jun 10 2018, 10:07 PM
I bought the screen from AA because I thought he had the best deal on the nut and I needed that. Best of luck!
Steve
Jun 10 2018, 10:28 PM
Curious is that a gasket or some sort of washer with the kit from AA
Lucky9146
Jun 10 2018, 10:45 PM
QUOTE(Lucky9146 @ Jun 10 2018, 09:07 PM)
Click to view attachmentNot A Kit!
The nipple and red gaskets were from Bruce Stone
The strainer and nut from AA
Don't recall where the copper gasket came from
Drums66
Jun 10 2018, 11:02 PM
QUOTE(jim_hoyland @ Jun 10 2018, 05:42 PM)
.......I also deleted the sock, no problems...going on YEARS!
andreic
Jun 11 2018, 10:27 AM
Where do all the washers/gaskets go?
maf914
Jun 11 2018, 03:47 PM
QUOTE(andreic @ Jun 11 2018, 08:27 AM)
I was wondering the same thing. In the order shown in Lucky9146's photo? All outside the tank?
Here is the PET diagram. See parts 8 to 14. Still not clear.
xperu
Jun 11 2018, 03:55 PM
QUOTE(Steve @ Jun 10 2018, 11:28 PM)
I got all I needed from AA . My old screen was gone, my have been the original. Easy to do with empty tank. Mike
