DaveBruen
Jun 14 2018, 05:11 AM
Looking for help locating the gasket that seats the rear window in my 914. Went to Pelican and Autohaus. No luck locating this part. Any suggestions?
Dave
jdamiano
Jun 14 2018, 05:42 AM
You use butyl tape for that. I forgot the size. I got mine from Amazon and reused the little rubber spacers. 914Rubber will hook you up with what you need.
http://www.914rubber.com
Mikey914
Jun 14 2018, 08:53 AM
Yes, it's not technically a gasket, but butyl rubber. Don't forget to put in the rubber setting blocks as they keep the glass off the metal.
Also if you are careful you might get the old one out in pretty much one piece. This makes cleaning the opening much easier. Just did mine and put in the dark tinted glass.
