ottox914
Jun 15 2018, 07:50 AM
What it says. Front bushings are gone. Have a kit to replace them. Need to remove arms to do this. Do I need to remove the strut housing or can I disconnect the ball joint easily enough?
Krieger
Jun 15 2018, 07:54 AM
Disconnect the ball joint. There is either a single bolt or pin that holds the strut to the ball joint. Remove it.
Krieger
Jun 15 2018, 07:56 AM
While your there check the condition of the ball joints.
toolguy
Jun 15 2018, 08:08 AM
disconnect at ball joint. . either the spanner nut or the strut clamp will do. .
Spanner nut needs a fork socket or you beat the nut to death with a punch and chisel and may end up needing a new one. .
Pinch / wedge bolt is easy to remove but somewhat difficult to pull the ball joint shaft out from rust and other crud. . You can 'tap' a wedge into the strut clamp slot to help relieve clamping pressure but a pickle fork works best [ but most often tears the rubber ball seal] I was able to find a replacement rubber on EBay from Bulgeria but took 6 weeks to arrive.
From my experience, I'd go for the spanner nut. . if you tear the ball joint seal, you'll need to replace the cover at minimum or the entire ball joint. .
