First thing yesterday I hooked up the heater cables.
The day became more complicated once I began installing the axles. I had placed the axles in the trailing arms prior to installing the motor. I torqued the CV bolts and the main axle nut. Now I was ready to attach the CV's to the transmission flange. When I went to turn the hub to line up the CV bolt holes, it would not move. I checked to make sure the parking brake was off and it was. After considering things for a bit, I backed out the outer CV bolts and the hub would move. To test what bolt size would work, I placed some washers on the bolts to effectively make the bolts shorter. Even then, after trying different combinations of washers, I still was having an issue with everything locking up.
At this point I decided the axle had to come out of the trailing arm. There wasn't room to take the axle out with the CV joined to the flange so I separated them and pulled the axle out separately. With the axle out, I could see that there wasn't much clearance between the rear of the flange and the inside of the trailing arm and could see where the paint had been rubbed off when turning the flange with no axle attached. At this point I wasn't sure what to do. I wondered it I could shim the flange away from the inside of trailing arm.
To check on that, I called Chris Foley. He had never heard of someone having this issue before but, then again, he hadn't dealt with the axles and flanges that were being used here. He did not think it would be a good idea to shim the flange. He also reiterated his concern about using the CV gaskets. He said there were some applications that called for these gaskets but not with the CV's that I was using. I thanked him for his help and suggestions.
The end of yesterday saw me driving to The Driveshaft Shop to get twelve 45mm bolts to replace the 50mm bolts I was using. The 50mm bolts worked on the transmission flange as there was plenty of clearance on the rear of them. This morning I removed all of the gaskets. To give a bit more clearance on the rear of the flange, I broke out the die grinder and took a bit off the outer edge and at each threaded hole. I installed the outer flange and maneuvered the axle into place. To line up the holes, I used a small pick to find the hole. To raise the bottom of the CV a bit, I stuck a thin screwdriver between the flange and the trailing arm. Once I got that first bolt started, I used the pick to find the second hole opposite that first bolt. With that bolt started, it was a simple matter to start the rest of the bolts. I torqued the bolts to spec and torqued the axle nut and, voila, I was able to turn the hub. Success.
Now I could installed the CV on the transmission flange. I repeated this on the other side. This whole process took up my entire day. There were many trips and down my ladder to engage and dis-engage the parking brake. So I am a bit behind on getting the car ready to start but am relieved that I have a job completed that I knew was going to be an issue since everything here was modified. And, as anyone knows who works with CV joints, I spent a good bit of time cleaning up my counter, my tools and me!!
