Moose01
Jun 18 2018, 08:53 AM
Guys,
My headlights are not working, i.e they are not popping up. I have fogs. Would it be the relay? Any ideas before I start pulling relays etc. The fuses are all good!
Chris
mgphoto
Jun 18 2018, 09:07 AM
QUOTE(Moose01 @ Jun 18 2018, 07:53 AM)
Guys,
Chris
Chris,
There is a small knob on the headlight motor, turn it, clockwise, I think, and see if the motor cycles.
If you turn the knob the wrong way it will loosen.
Watch your fingers, when the motor cycles quickly.
If it doesn't cycle could be power issue.
Misaligned relays could be the issue.
jim_hoyland
Jun 18 2018, 11:04 AM
Also, look at the small diodes. They can come loose and prevent the motor from operating. They are small and kinda hidden by what looks like black tape; lower outside of each motor.
marksteinhilber
Jun 18 2018, 02:40 PM
If the fuse is good:
1. turn the knob on the motor just as Jim said. If it kicks on and cycles the headlight to the up position, or if up already, to the down position, then you know the motor is okay and there is power to the front by the relay. It also suggests that the local ground up there on the body is good, but those could always use cleaning/maintenance. If turning the knob does not kick on the motor, then you may need to check for voltage reaching the front of the car and may indicate a problem with the headlight switch.
2. Try swapping in a known good round standard relay inside the front trunk next to the headlight motor with switch off. Turn the headlight switch on and see if that one headlight comes up. Both side relays usually don't fail at once.
3. Go back and re-check what you think is a good fuse, clean the fuse block terminals and put in a new fuse. Ask me how I know....
4. Check for a loose wire on the back of the fuse panel or on the switch, especially if someone was working under the dash. Ask me how I know....
5. If all fails, post your efforts and ask for new suggestions, and repeat. Ask me how I know...
Dave_Darling
Jun 18 2018, 09:30 PM
There is one relay on each headlight motor. So chances are that both staying down is not a relay issue. You can try to verify by swapping the headlight motor relays (they're right next to the headlights) with some of the relays on the relay board in the engine bay.
It's much more likely to be something in the wiring or the switch. Most other things would only affect a single light.
--DD
Jun 18 2018, 09:37 PM
QUOTE(mgphoto @ Jun 18 2018, 08:07 AM)
Watch your fingers
Moose01
Jun 19 2018, 08:24 AM
I am pretty sure it is the headlight switch, which is behind the dash face panel. If I pull the switch out the parking lights come on at the half way point. However when fully out the headlights do not come on and they do not pop up. I changed the relays at the lights, and the fuse, although it looked good.
Any ideas on where to get a new switch at a decent price?
Dr Evil
Jun 19 2018, 10:07 AM
QUOTE(Moose01 @ Jun 19 2018, 10:24 AM)
Classifieds on this forum. Lots of good used ones in peoples stashes.
Geezer914
Jun 19 2018, 11:57 AM
My Dad had a saying "if it's broke, take it apart and see why, you can't F__k it up any worse and maybe you can fix it" I have taken the headlight switch apart and cleaned the contacts and it worked.
toolguy
Jun 19 2018, 03:41 PM
Headlight UP function is terminal "K" of the headlight switch [gray wire]. The headlights pop up on position 1 [parking lights] but does not illuminate the bulbs until position 2.
Headlight DOWN is the green/blk wire on terminal 30b
As a test if the switch terminal K is bad, try moving the Gray wire from K to terminal 56, which will delay the headlights pop up to when switch is in Position 2.
Dave_Darling
Jun 19 2018, 04:44 PM
If you want to know what the inside of a headlight switch looks like, here you go:
https://members.rennlist.com/pbanders/headl...h_internals.htmCourtesy of Brad Anders, of D-jet Bible fame.
--DD
Moose01
Jun 20 2018, 01:04 PM
Fantastic help guys! That is what I needed.
marksteinhilber
Jun 20 2018, 01:44 PM
internal switch cleaning described above may do the trick! I had a problem where one of the headlights would not go up and down without giving it a little help spinning the knob on the motor. I removed the motor to the workbench and opened up the gearbox that the wires go into. There are contacts inside there for limit switches. I found old grease and weak spring tension on some contacts. I cleaned and regreased the contacts and that restored proper function.
Moose01
Jul 8 2018, 08:59 PM
So much for it being the switch. I managed to find a used one on fleabay, replaced it and it was more of the same. Then put the old one back in and I had lights, but still no pop up action. Obviously a wiring issue now
Anyone need a good used switch
Mark Henry
Jul 8 2018, 09:29 PM
I imagine you did this but the first thing I try is spinning the fuses in the fuse block, then cleaning the grounds...
ClayPerrine
Jul 9 2018, 05:29 AM
I am gonna ask a really stupid question...
When you are testing this, is the key in the run position? If the engine is not running, or the key in the on position, the headlights won't come up.
If the key is on, check the right most fuse in the fuse block. If it looks OK, take it out and clean the contacts on the fuse box, and replace the fuse.
