I’m having a bit of an issue with getting the heater blower to work...
The motor bench tests fine
The wire on the heater control lever is connected correctly
When I pull the lever back, I can hear the relay clicking in the engine bay
However, when I connect the fan to the heater wire the motor does not run. I confirmed that brown connected to brown and green to yellow, just like the picture below.
I was holding the motor - so it wasn’t separately grounded - would that be the issue?
Any ideas ?
