QUOTE(alexkirkham @ Jun 22 2018, 11:21 AM)
... my 73 car has every other little bit, but not these! don't have too much of an idea how easy they are to come by...
am in london, UK
thanks!
alex
Alex,
I would suggest that you find a jack from a 1980s vintage Nissan. The scissors jack that comes in the Nissan is far better than the factory 914 jack. Plus it is readily available and far cheaper than the 914 jack.
From experience.... I had the screw on a factory jack break above the shuttle with the car halfway up. I was trying to remove the flat tire at the time. I had to borrow a floor jack from the gas station attendant to finish changing the tire.
Now if you want the original jack for show, then go for it. I keep an original jack in the 914-6, but I won't use it.
Good luck.
Clay
