86motoman
Jun 12 2005, 04:15 PM
Front tires wearing out after seven months of use. It wears both tires out consistently in the middle.
Please tell me this is just an alignment issue, and it is nothing else that will cost a bunch of time and money to fix. I am going to college and have very little dollars. Any help is appreciative.
michel richard
Jun 12 2005, 04:23 PM
Ohters with more experience will chime in, but I believe that the first thing to look at, under those circumstances, is overinflation.
Michel
Joe Bob
Jun 12 2005, 04:32 PM
Air.....muy grande mucho....
86motoman
Jun 12 2005, 04:40 PM
I will check the air pressure as soon as I get off work. That would surprise me because I haven't touched them since Les Schwab put brand new tires on in December.
86motoman
Jun 12 2005, 09:44 PM
I checked both tires pressure and they were at 32lbs.
What would be the next thing to check?
smrz914
Jun 12 2005, 10:06 PM
Tire presure is something you have to play around with. You need to find what your car likes. Since 32 was too much then you need to take some air out. If you want to even them out a little underinflate them and drive for a while. You should also rotate your tires once in a while. Take the tires down to 30 and drive for a while and see if you can get the outer edges to wear out. If you can at 30 psi then once they are where you like them the inflate them to 31 psi. If 30 ps is still to much, bring it down to 28 and keep working at this untill you find the wear you like. Temperature makes a difference so if you check when the tires are cold always check when they are cold. Tire presures are almost always given when the tire is cold so keep that in mind. Good luck. This is a long term experiment.
86motoman
Jun 12 2005, 10:09 PM
Thank you Paul,
I will experiment around with the pressure.
Jun 12 2005, 10:15 PM
my street tires like to be run at 24lbs, took me a while to find that number, they were listed at 34lbs ...
Andy
dflesburg
Jun 13 2005, 05:39 AM
I have had the same tires on my 914 since 1992 when I bought the wheels. Pull your motor, take your car completely apart and have it dipped, your tires will last a lot longer....
Jun 13 2005, 09:32 AM
QUOTE (dflesburg @ Jun 13 2005, 04:39 AM) |
Pull your motor, take your car completely apart and have it dipped, your tires will last a lot longer.... |
that is soooooo true ...
