QUOTE(Steve @ Jun 26 2018, 06:26 AM)
The Factory spring spec here can not be converted to the typical lbs per inch spring rate we are used to, without additional information.
The Factory spec is force at a given length, as in compress the spring to the length in the spec and you should get the force listed in the spec. So for springs with 1 green dot if you compress to 239 mm (almost 9 1/2 inches) you should get the 220 - 227 kp of force, about 485 - 500 lbs.
In the typical lbs/inch spring rate there is no specificied length at which we measure the rate, we just compress the spring until we have a stable reading and note the reading. Then we compress an additional inch and note the increase in the reading to get our lbs/inch spring rate. I used to crank the spring down until I had an even number of puond, such as 100 pounds of pressure. Back then I remebered how many thread per inch the spring scale had and I could just crank it down an addition 11 turns (or what ever the number was) and take my reading again. if it was now 240 pound then the rate was 140 pound per inch. For lenear rate springs the pressure increase as teh spring is compressed each inch should be the same until coils start to contact each other and limit their travel.
If you are progressive springs and not measuring springs with a linear rate then you need to crank them down to the pressure range your spring are going to be while installed. The rear springs of a 914 carry somewhere around 550 pounds or so depending on the total weight and weight distribution. So for a progressive spring I would crank down to 500 lbs and then another inch and note the pressure, then another inch and note the pressure and then anther inch and note the pressure. For progressive springs change in pressure as the spring is compressed will be higher. Maybe the first inch added 100 pounds of pressure and teh second inch added 115 pound of pressure and the thrird inch added 140 pounds of pressure. You build a profile of the spring rate for the spring.
Jim
