thomasotten
Jun 27 2018, 12:37 PM
For those of you who have done the 100mm fuel cap through the hood, I am having trouble finding the filler. I can find the 100mm Blau Cap, but the only place I have found the filler is overseas. Who has them?
Jun 27 2018, 12:58 PM
Sierra Madre
thomasotten
Jun 27 2018, 01:38 PM
QUOTE(mepstein @ Jun 27 2018, 10:58 AM)
Sierra Madre
I can only find the cap there.
Jun 27 2018, 01:58 PM
QUOTE(thomasotten @ Jun 27 2018, 03:38 PM)
Sierra Madre
I don’t know if they sell the parts individually but I know they have the kits, I’ve purchased at least half a dozen in the last 2 years.
Call them.
mb911
Jun 27 2018, 02:10 PM
There is a meber right now working on making a kit. Very cost effective. His name is Martin Baker.
Martin Baker
Jun 27 2018, 02:49 PM
I have them...necks and caps. Also, don't be fooled. These caps are not measured by the cap overall dimension. They are measured by sealing surface, I was mislead by Armando's web site, and it cost me $500 in freight charges. 80 MM is the correct size for the size used on the 911 and 914/6 types, through hood fillers.
Here is the set up I built. I had a friend tig up the neck in the tank, and the die for the drain tray was made by Roger Hamlin for me.
Martin Baker
Jun 27 2018, 02:59 PM
Here is one I did on my race car.
Martin Baker
Jun 27 2018, 03:06 PM
The plan is to start doing a complete tank set up. I have the parts to build three. I have 50 caps and 50 necks at the moment. Here is what it all starts off looking like. I do an electrolysis treatment on the tank after I am complete and the tank look like new inside. I have fixed some pretty bad ones.
Martin Baker
Jun 27 2018, 03:45 PM
For reference
Retroracer
Jun 27 2018, 07:11 PM
I have a spare filler that works, but its not as deep as the the you show in the photo - maybe 25mm from memory? PM me if you're interested in it.
I took the easy way out and simply attached the Blau cap to the top of the stock one....
- Tony
Retroracer
Jun 27 2018, 07:25 PM
Martin Baker
Jun 29 2018, 08:59 AM
So if you want to use the stock filler but have the cool cap, here is whats possible without your cap protruding through the hood so far...first cut out the base of the Blau cap as seen here.
Martin Baker
Jun 29 2018, 09:00 AM
Then attach the stock cap into the area removed from the Blau cap, and use a strong two part adhesive to secure.
Martin Baker
Jun 29 2018, 09:05 AM
And as a result you have one close to the same height as one with a welded in 80MM neck.
Larmo63
Jun 29 2018, 09:27 AM
That's cool, and your race car is insane, love it!!!!
Martin Baker
Jun 29 2018, 10:03 AM
QUOTE(Larmo63 @ Jun 29 2018, 08:27 AM)
Thanks for that. Its been a long road. I just put my Cibie Pallas on. My latest endeavor to close up the accuracy gap on it.
LIGHT ER UP!
