186 MPH if you have the balls to get a 914 there, I can tell you several ways to do it.
Now back to the speedo itself.
Depending on where you pulled the PN from it has many a possibility. You most likely have a 914 can. The lip was painted to make the silver bezel look so many desire.
You can tell by the overspray on the can. It has an aftermarket face on it, as the original VDO dials, put the 300 KPH at the bottom of the dail, in the 6 o'clock position if looking at it like a clock face. There is a company in Australia that produces the 300 KPH speed face to retrofit into the gauge. Their 300 is in the position of yours, they do this by moving the needle on the speed and the starting point on the gauge. As long as your not hitting the stops in the swing your good to go.
For reference this is what the period correct 911 300 Kph Speedo looks like
Note the needle stop as long as the scale matches in degrees from the scale your putting the face on your good to to go. If not you have to change the gearing in the speedo mechanism, or in the transmission that drives the speedo cable.
BTW, this speed was still optimistic for the 911 at that time. The 1975 930 Turbo would only get to a factory top speed of 251 Kph, 266kph was the factory top speed. In the 80s they could have gone faster, but where limited back to 250Kph.
So as long as it is functional run it the way it is, all speedos are optimistic in cars. Someone wanted to make people think the car was capable of that speed, or it was a easy way to build a true KPH speedo. If it is accurate I would run it. I would clean up the bezel a bit and make it black or purchase the rings to do it in Aluminum.
In the US we had 120 MPH and 150MPh speedos, that latter was also somewhat of a dream. But with more power and the proper aerodynamics and transmission gearing, and tires, and nerves of steel then anything is possible.
You don't happen to have a matching 10K Tachometer do you?
BTW
