QUOTE(Mark Henry @ Jun 29 2018, 08:32 AM)
So what have you changed to need shorter pushrods?
You can't remove tips, I imagine if you're good with a lathe you could undercut the tip and hammer the tip in further. Never done this so it's totally at your own risk.
If you are using 1.7 rockers and 911 adjuster I say do it right and use real CrMo pushrods like the Manton. Not something you want to cheap out on.
I tried the cheap steel pushrods (like EMPI) and bent them like a pretzel. BTDT 25+ years ago.
I did however cut a stock pushrod in half to put a threaded stud in so as to construct my own adjustable rod - doing the kind of thing you are doing. Then I bought the CrMo cut to size rods and made my own length. In the end It wasn't much different than stock in length and the original pushrod I cut up was tough stuff.
