QUOTE(Wew @ Jun 30 2018, 06:22 PM)
Ps I installed the led lights and am getting the quick blinker, which relay is the right one for this scenario. I have searched but have found nothing definitive
I'm surprised you're getting hyperflashing as the stock 914 flasher relay won't hyperflash but will have other issues driving the turnsignal indicators in the tach when changing to LEDs.
LED-compatible flasher EP26 available at many FLAPS is pin compatible although it doesn't fix the turnsignal indicator issue. I resell EP26 modified to drive the turnsignal indicators. The flasher is one of the relays above the fuse panel. Not sure which one it is. I have usually turned the flasher on and follow the clicking to find the relay. Maybe someone else can chime in with regards to which relay is the flasher.
