QUOTE(bdstone914 @ Jul 1 2018, 06:41 AM)
Can you post a picture of the finished pedal mod ? I sometimes get requests from customer having their pedal rebuilt and have issues with long legs and big feet.
If the OP wants a pedal to modify brake pedal I will offer one free for shipping.
Here's how I did mine. I did not want to remove the pedal box to weld the brake pedal over so I cut off the brake pedal at the end of the brake arm with a hacksaw. Then I welded a short flat metal bar with two holes drilled through it to the right edge of the back of the pedal. I also welded a small triangular metal gusset between the short arm and the back of the pedal to prevent the pedal from bending over under braking pressures. Then I drilled two matching holes through the brake arm, in place, and bolted the short flat bar arm with the pedal to it. This resulted in moving the brake pedal about and inch to the left from the stock location. It's easier to do than it sounds. The next three pictures should suffice.
Click to view attachmentClick to view attachmentClick to view attachment
