I'm a bit late in getting an update out. But at least I've been busy.
We made a 1800 mile trip to pickup a donor car in LA and stopped by Roger Sheridan's place in Paso Robles to pickup the fiberglass front end. Quite the trip, but except for smoke virtually everywhere along the way, and taking GPS routes the weren't always the smartest choice, the trip was uneventful. (the way I like it.) My wife decided I should not embark on this journey by myself, so she came along to keep me company. And aside from asking every couple of hours "Tell me again, Why are you getting this car??" She didn't see the beauty of a pristine body. I look at bodies all the time, I know a good one from a bad one. We'll this one is just what the dr ordered. So, I'm going to cut it up and fix mine. Yeah, I know, I'm a bad person.
So there is a method to my madness. The rear of the Screamcicle has a lot of work done to it. Custom work that I don't want to redo. The side vents don't come with Rogers kit. They are beautifully molded into the side. The firewall is custom and done to mm of the engine rotating components. the roll cage is custom incorporated into the front and rear sections as well as fit into the dash. The fiberglass work is bonded to the tub and worked in nicely to make it look like it's always been there. The rear deck lid has a custom spoiler that molds into the rear fenders.
Enough of my rationalizing.
Here's my plan of attack.
Corner balance check blue car - done, it looks to be what I expected from a stock car without drivetrain. No huge variances.
Inspect for previous damage - No damage whatsoever.. Ok, the paint is faded...
Put blue car on the rack and remove suspension - today I hope, (it's gonna be hot and smokey)
Build chassis jig - got the major parts to construct the jig. more on that
Bolt to front and rear bumper mounts, could be a challenge to unbolt, I need to work that out.
Add arms that locate the mounting points.
Check and adjust for gaps
Bolt together jig and blue car
Unbolt blue car
Put the suspension back on the blue car so I can roll it out.
Put white car on rack
Pull engine and trans
Unbolt suspension
Move chassis jig into place
Cut nose off white car leaving a couple inches for overlap
Measure and cut nose off blue car leaving a couple of inches for overlap
Mount nose to the jig and body leaving overlap
Connect both pieces are in place and mated using coleco connections
Measure and mark for cutting line
Plasma cut thru both pieces leaving a clean line on which to butt weld.
Possibly do this in sections leaving sections always connected. still working this out.
Once the nose is in place and the suspension point are where they should be, then I'll cut out the bad A pillar and do that repair.
I know I'm leaving things out, but you get the jist.
Oh, my wife had a great idea for the rear end. Make a tire trailer for it. The white car already has a receiver hitch.
