Happy 918 Day!
Lot's been happening, Wow, it's been 2 months, sorry this will be a long post.
My last couple of weeks…
I spent some time getting back to the art of fiberglass work. My little experience with the trailer caused some damage and needed repair to the front splitter. I started by calicoing the pieces back together and determining a way to hold things together while things dried. I worked from the front first so I could make sure the 2 halves lined up. I used angle hair to glue them together, clamped them and let it get hard. Then applied some layers of matt to provide strength and to fill in the gaps. (yes, big gaps.) I worked the front a bit and then removed the front end, (hey, that’s kinda handy). Working from the back side I applied several layers to get the strength back where I wanted it. Then I moved back to the front where I could get it at least close.
Click to view attachmentClick to view attachmentBroke the shop laptop. Couldn’t get ancient laptop with broken monitor and broken keyboard to switch to the exterior monitor. So I ordered a new monitor cable, tore it all apart and managed to get it back together again… and bam, now I have 2 monitors and an external keyboard.
Swapped my Press’ 12 ton jack to my Affordable Tubing bender that came with an 8 ton jack. That took a bit of fab work, but it worked out fab! It is said to allow bending of .120 wall tubing.
I promptly used the new/downsized press to install some bearings for a friends rear end rebuild for his Jeep. Yay, it still works!
Finally back to the 914.. I’ve had problems from time to time with the fuel pump not working. I previously had wired in an alternate route so I wouldn’t be stranded. Well it came in handy the other day when my friend came by and wanted a ride. So this week I did some tracing and found a connection to the fuse block (aftermarket) had gotten hot and was crusty. I cleaned up the terminal, put some dialectic grease on it and the new fitting and I think that’s going to take care of that. I’ll leave my bypass in place, just in case.
Still haven’t found wheels that I like and can afford. So I decided to take a chance at straightening the 8” wheels. A visual inspection would have said they were fine. I could still feel they were off just driving on the driveway. Note: This work is minus the tires of course. This way I can have a race tire set and street tire set. Currently only 6 wheels are straight. 4 – 18x11” and 2 of the 18x8”. I was successful in straightening one of the wheels before my setup bent on the 2nd. I'll send it to a pro but in the meantime I picked up another 8" wheel and that makes 2 full sets. Then I started searching for affordable tires.
I've been working on the ECU trying to get something I could tune. The existing one is tunerlocked by a shop in NJ that is now closed. I picked up a couple spare ECUs at the wrecking yard and started learning. Decided to purchase HPTuners. It's a learning curve, but I think it will work to get my redline back where it should be.
Lately the project is installing a wide band to help with tuning. I'll be setting it up to log data with the laptop using the scanner app in HpTuners.
2 days of autocross earlier this month.
https://www.youtube.com/watch?v=PFXOVJmNi3kAnother comparison run of the 2nd day. Exciting day for me as my normally dominate competition had a backup car they were going to do a champ style endurance race so it wasn't quite up to the horsepower and suspension tuning of their normal LS powered RX7. So I actually had a chance. I was behind them on Saturday, but managed a class win on Sunday.
https://www.youtube.com/watch?v=0m08hQtTxWsThese will help get a bit closer to the competition. I found the Hoosiers I was looking for at John Burget Tire out of the east coast. 580 for all 4 shipped to my door. Not new, but close enough for me.
Click to view attachmentWell, if you've read this far. Thanks for listening to my dribble..
