Have you been contemplating making the switch?
There is a reason the factory did!
Benefits are well documented in the Garage.
I offer three versions,
Base - You supply the trans, I supply everything else. (shifter, rods, coupler's, boots, bar, mounts & bushings ect.)
Partial - All the parts in the Base pkg. + a
side shift rear cover,
side shift console,
internal shift rods & a gasket set.
For those prepared to convert their own tail shift trans into a side shift.
Full - All the parts in base + a freshly serviced side shift trans-axle.
BasePartialFull meal deal+ship
Kits include:
all new gaskets, bushings, mounts, cone screws & covers.
Shifter's are cleaned rods freshened, new bushing installed and lubed where appropriate.
Trans-axle equipped with *New* 1st/reverse slider & as-new syncro's & dog teeth re-purposed from core inventory.
Full pkg requires return of usable core in provided container.
