For all of you that have had your rotating mass balanced, I have a few questions:
1) Is the crank spun with the gears and/or woodruff keys installed?
2) Is the fan spun with the crank or is it usually balanced separately?
3) Does the bobweight include the rod bearings, pistons rings, a circlip ndweights?
And lastly, can someone recommend a shop in San Diego, preferably North County, that can do this work.
Probably doesn't matter, but this is a T4 build with 96mm KB pistons and AA H-beam rods, stock 71mm crank.
