QUOTE(914Sixer @ Jul 8 2018, 10:32 AM)
Sounds like it may be stopped up or gummed up. If you take it off you can try putting some lacquer thinner in ports and let it set for a while. Do this set a few times. Thinner will turn dark brown when you dump it from the gunk. Hook it up to 12v and you can feel if it is running or not. I do not recommend taking it apart. It is REAL EASY to lose the rotating cams in the pump housing.
This original pump was moved to front under tank several years ago, and is very clean and was running last week when I hot wired it to a battery. Now it doesn't want to run at all, even after a good whack or 2! Appears it is time for replacement, and have to figure out hose configuration from 3 port to 2 port. All fuel lines and filters are new.
