jdamiano
Jul 14 2018, 09:40 AM
The rubber between my windshield and dash is hard and cracked. Windshield and dashboard are fine. Is it possible to replace the rubber without removing the windshield or dash?
mgphoto
Jul 14 2018, 10:07 AM
QUOTE(jdamiano @ Jul 14 2018, 08:40 AM)
No windshield has to come out.
Old part has metal clips, new rubber part doesn't.
DRPHIL914
Jul 14 2018, 10:27 AM
I did this with window in, was not easy it kept falling apart, now my windshield is out
Mikey914
Jul 14 2018, 11:29 AM
The answer to if the windshield needs to come out is , depends on who's it is.
The factory has a metal clip that i was never able to get fully engaged back on the seam it sits on. Even using a custom toll to install (paint mixing stick), I could not get it uniformly installed. So I made a version that has spring designed into the part. It's much easier to install.
Note for install - I notch the shape of the pillar on the 1st side I install, then cut about 1/4 longer than I think it needs to be. Installation begins with both sides at the pillars and walk the seal to the center. If it's too long, keep trimming between fittings until it does fit, it will actually over center and pop into place, making a perfect seam at both pillars as they have some give.
When installed they look uniform like they should.
https://shop.914rubber.com/914-Windshield-t...m?categoryId=-1And only $18.99. These were once as high as $42 elsewhere.
Here's my original write up, it may be handy.
http://www.914world.com/bbs2/index.php?sho...p;hl=windshield
AZ914
Jul 14 2018, 11:38 AM
I used the 914Rubber part and left the windshield in.
I referenced this thread:
http://www.914world.com/bbs2/index.php?sho...c=84862&hl=
jdamiano
Jul 14 2018, 01:39 PM
I just ordered the rubber so I’m going to give it a try.
Coastal6
Jul 14 2018, 11:22 PM
You can get the rubber seal installed with the windshield in place. The aftermarket seal from 914 rubber does not contain the metal insert that the original factory seal had. You can push it in place with a little help from some silicon spray and a plastic trim tool.
Chris914n6
Jul 15 2018, 01:09 AM
Depends if your windshield is glued to it. Mine is original and pulled out fine. Couldn't remove the dash frame with it in, rubber was too hard.
Coondog
Jul 15 2018, 03:22 PM
Just ordered, I love 914 Rubber....
jdamiano
Jul 15 2018, 05:56 PM
Be ready with some dental tools before you start this. I just removed the old one and it was a mess. It came out in a million little pieces. I had to pull the metal out with needle nose pliers and it came out in small pieces as well. You have to be careful not to crack the windshield or damage your dash. I just did it so it can be removed but be ready!! No fun! I will let you know how the 914rubber version goes in.
Larmo63
Jul 15 2018, 06:01 PM
If the seal is old and brittle, it will come out in dribs and drabs. You'll find little pieces of it all over your car. It can be done it the glass in situ, I've done it three different ways. Way back when, the first time I tried this, I cracked a windshield getting it out. I did another car with the windshield in successfully, and the last time I did it on Underdog, I did it while the windshield was out.
I recommend option #3, but be careful when you do option #2.
Geezer914
Jul 15 2018, 06:48 PM
Used a dental pic to remove the old cracked rubber seal and metal clips. Used a paint stick to install. Windshield was not removed. 914 Rubber is the best replacement. Coat the seal with 303 Aerospace protectant before you install it.
jdamiano
Jul 21 2018, 10:22 AM
Picked these up at Harbor Freight yesterday. Small but worked perfect to get every last piece of the old rubber out.
jdamiano
Jul 21 2018, 12:16 PM
914Rubber replacement went in smoothly and looks great.
